deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Tue Jan 18, 2005 3:02 pm
All your problems are in the switch. Mid 80s-90s nissans all have the same design and it is a common problem. You can pop you lever/switch out, take off the white panel and clean the finger contacts. This will work for a while but eventually it will fail again, prying up on the lower contacts for the fingers a little helps, but dont try bend the actual fingers down cause it will never work. New switch is the best way to go, they are 60 bucks from nissan for non-cruise im pretty sure.
