Postby
drksol22 »
https://forums.nicoclub.com/drksol22-u71949.htmlWed Oct 13, 2010 6:50 pm
I have a metal fuel line that has a crack in it. i was wondering if i can cut it off and put a rubber line in place of the metal up to the rail without a bead on the line?
Postby
DanThaMan »
https://forums.nicoclub.com/danthaman-u130058.htmlWed Oct 13, 2010 7:26 pm
cut the section with the crack in it off of the line with a tubing cutter (the kind with the sharp wheel that you turn around the tube) get yourself a piece of metal fuel line from the auto parts store and some compression unions, and put it all together
Postby
Morph »
https://forums.nicoclub.com/morph-u11938.htmlThu Oct 14, 2010 11:15 am
AZhitman wrote:That's a lot of work for a $5 part.
Agreed and working with lines like that for a first timer is quite difficult. Do as AZ suggested and get one from a junkyard just make sure there aren't any cracks in that one.
