Broken Flywheel Bolts - too much power? lol
CA19DET
ok so i tore into the engine yesterday and after a co pression test (160 flat across) and removing the oil pan and valve covers etc, the engine looks to be spot on.. so we removed the gearbox to find
I broke 3 of the flywheel bolts and the flywheel was bout to vibrate itself off and probably flyout the bellhousing lol
dont know if this is a resulf of not fitting it properly last time, too much power like i would like to think lol, or and unbalanced flywheel.. but it means time to upgrade...
so i'll be looking into some ARP flywheel bolts and probably the SR lightweight flywheel & Clutch Combo..
(anyone have access to CA20 reduction type starter?? - was trying to get it locally and got shafted)
float_6969
I can get them, but shipping would rape you...
CA19DET
hmm. how much are they (and this is the starter we are talking about here right) and how much do they weigh??
Pumaking
as long as it done via Fedex's or Fedexkinkos. shouldnt cost more than $10 to ship b/c fedex doesnt charge much on weight only dimensions of the package.
CA19DET
yeah but its international, thats why i need the weight, i am outside the USA
c-rad
Car: 1991 Nissan 240SX w/CA18DET
I sent a set of flywheel bolts to new zealand and it only cost me $5 through Global Priority Mail. Got there in 4-6 business days.
CA19DET
c-rad wrote:I sent a set of flywheel bolts to new zealand and it only cost me $5 through Global Priority Mail. Got there in 4-6 business days.
hey i emailed you to see if you had anymore flywheel bolts actually.. Do you - i'll take em'
but we were talking about shipping the CA20 reduction type starter internationally soi can use a SR flywheel and clutch etc...
BUT let me know if you have the bolts and shipping to Trinidad, incase i cant get them locally.
float_6969
I THINK this is the starter you're after actually. I could be wrong though...
http://cgi.ebay.com/ebaymotors...QrdZ1
Dattebayo
according to http://www.boschusa.com, there are two part #'s for the CA20E.
The first (SR148X) is a direct drive starter and has two original manufacturers and designs,; Mitsubishi and Hitachi.
The second (SR255X) is the reduction type starter manufactured by Hitachi only.
So basically, Float is correct!
