Broken Fly wheel bolt
newdude1
So Im extremely pissed right now. I just broke a fly wheel bolt. The torque for them is 90 ft lbs right? Also how do I fix it? Remove the bolt and heli coil it?
snake240
Car: 92 hatch SR20DET
go to advance or somewhere and get an extractor bit set. you drill a pilot hole if you can with a small drill bit then use the extractor. its basically a reverse drill bit. it goes in drilling it to the left.
newdude1
K Ill give that a try. But was I right on the torque specs>?
snake240
per fsm it is 94-101 ft lbs. dont forget the loctite.
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
Yes that's the Right torque. I broke 2 myself. E-z out didn't work for me as I got it to about 80 ft. lbs. Reverse drill bits didn't work for me either. I had to drill a small pilot hole, then try said methods, then I drilled threw the hole bolt bigger and bigger until there was a thin sleeve of a bolt remanding ( shaped like a O ). I then collapsed one side ( the sleeve of a bolt collapsed looked like a C shape instead of a O ) and bent the remands until I could extract it. It was a true PITA to do that 2 times. It's really hard to explain and I hope some one understands.
I ended up only go to 70 ft. lbs. with lock tight with the new bolts. Only heli coil it if the threads are stripped.
garagelu
Car: 1995 240sx w/ sr
you probably reused your bolts didn't you. If you buy new bolts, that should not happen.
I stretched 3-4 bolts when I reused mine. I was lucky I caught it before it snapped. From now on I will always buy new flywheels bolts.
newdude1
I tried that ez out thing and broke the bit in there so now thats stuck too. Guess Im just gonna have to drill it out.
And one know what fly wheel bolts I can use?
Modified by newdude1 at 4:13 PM 5/15/2009
newdude1
supreamS14 did you have any problems with only torquing them to 70?
Justin35ll
Car: s13 coupe sr20det
I torqued my reused bolts to around 100 ft lbs with no loctite. God I hope they stay tight
newdude1
lucky. I couldnt even get mine to 80 before it broke.
supreamS14
garagelu wrote:you probably reused your bolts didn't you.
No! The new bolts broke!
garagelu wrote:If you buy new bolts, that should not happen.
It did! $#!+ happens.
newdude1 wrote:supreamS14 did you have any problems with only torquing them to 70?
No. Loc tight has kept them in place even @ 7500 RPM!
duffman1278
Car: 89 240sx Hatch, the wildcats!
You're going to have to keep working on that reverse drill bit method because I doubt you have any space to weld on a head from an existing bolt.
It's going to be a PITA especially with the amount of torque thats set already on it.
Try putting some WD40 and let it set for awhile then do the reverse drill bit method.
