l0nestar »
https://forums.nicoclub.com/l0nestar-u38221.html
Sat Dec 16, 2006 9:13 am
Mello, What is 'reasonably priced'??
Integra7, Here is what I was looking at from McMaster-Carr (McMaster.com)
BEGIN QUOTE:12 x 93210A030 - $2.28 Each $27.36Metric Black-Oxide Finish Steel Setup Stud Round Shank, M8 Size, 50mm Length, 1.25mm Pitch 1x 93795A230 - $4.48 Pack $4.48Class 8 Zinc-Plated Steel Conical-Top Locknut Hex, M8 Screw Sz, 1.25mm Pitch, 13mm Width, 8mm H, Packs of 50 1x 93475A280 - $9.62 Pack $9.62Metric DIN 125 18-8 Ss Flat Washer M10 Screw, 10.5mm Id, 20mm Od, 1.8-2.2mm Thickness, Packs of 100
Merchandise Total $41.46
END QUOTEI forgot about the yokes being different. I could probably drop the pack of washers for $9.62, but meh.. What are the dimensions of the stock studs? The McMaster-Carr site is awesome to look parts up on as well! BTW, where did you get your JDM studs from and how long did it take? (If these studs are good, They can ship today ) Thanks for the help as well!
