Mike W. »
https://forums.nicoclub.com/mike-w-u275015.html
Sun Dec 06, 2020 11:21 pm
Interesting. I'd never considered exhaust corrosion as an engine management or emissions problem. The logic is clear, I just hadn't thought of it. On the later R50s, I'm assuming all the 3.5s, the front O2 sensors, which are the important ones, are 3 wire and would be subject to problems with corrosion and resistance in the circuit. Oddly, the rears are 4 wire which means they have their own ground, so they should be unaffected by corrosion/resistance.
BTW, seat of the pants, do you notice any difference? Diverging a bit, I once replaced a MAF sensor on a BMW of mine with a generic one. Worked ok for 11.5 months when it failed. Rockauto did replace it free of charge, but I decided to replace it with a VDO, which is an OEM. And there was a difference. Subtle, but there. Mostly smoother, might have been a little more responsive. No CEL prior to the failure, but I wonder if this might be the same thing, not dramatic enough to set a code, but enough to make a difference.
$13 shipped? For a custom part? That's crazy cheap. I'm thinking I'll solder or braze a wire to the exhaust if it's missing, and I've neither seen it or looked for it, but for $13 even this cheapskate might just buy it new.
So you took the mv readings between the exhaust and a chassis ground?
