Broken Cigarette Lighter on QX4
sailor420boy
Car: 2000 Infiniti QX4
Hi, I have a 2000 qx4. My front dash cigarette lighter is broken. It seems that the pin inside it is broken off, if I plug in phone charger or Ipod charger, they dont work. But they work fine in tailgate outlet and the outlet behind the center console. I was wondering if anyone knows a website were I can get the part and advice on this??
volp
Car: 99 Infiniti QX4
you can probably get a replacement one from autozone. when I took the dash off to hook up my subs it didn't look too complicated. (99 QX4) you might be able to wire up a universal one.
sailor420boy
Thanks for the advice. im gunna order the part and give it a try
W O T
Car: 2001 Infiniti Qx4
Might just be a fuse... dont know if that one is fused seperate or not.
First thing I would do is just pull it out and see if its getting any voltage, check fuses, then go from there
Hes right about the universal ones though, there $16-$25 at bigger auto places and work and mount fine
