broken camshaft bolt
yoozef
Ok so i had to re-do my headgasket due to it not sealing... when installing camshafts i forgot to change my torque wrench and the front intake bolt (the longer on out the two) snapped. It snapped about an inch inside the head. I tried drilling into it and then using the easyout, but that didnt work too good as i am missing the small bits. Can i drive it like that to the shop? Any other tips?
yoozef
CRyan
Car: 1997 Nissan 240SX
easy out?
Anytime I have had a problem like that I have just bought a reversing drill bit. basically one that cuts counter-clockwise instead of normal.
DuckyD
Car: 1995 240SX
yoozef wrote:Image
haha good show!
And I have never had luck backing out broken bolts or studs :(
yoozef
hah ok i had a try at it today... drilled through the stud until it collapsed, put the reverse bit in it and that mofo was made in china :/ so now i have to get a diamond tip drill and redo everything over again, i'll report back tomorrow
yoozef
ok, if someone else has the same problem im just gonna post how im doing it and how it's coming out. I got a cobalt drill bit, because anything else wont make a dent in the hardened steel that tap it made out of. Even then i had a hard time getting anything, so i got a punch and a hammer and went at it a little. That did the trick, it loosened the broken piece a bit and i could resume the drilling process. Im still a half inch away from the original position, but hopefully i wont have any more surprises along the way. I'll report back tomorrow with the results, hopefully it'll be up and running with no further problems...
