Broken brake light switch
matt_240sx
Car: 1993 240sx Hatch
so yesterday my car died because the tail lights were on. my step dad checked it out and it was a rubber stopper thing on the brake pedal that turned the lights on and off when i pressed the brake pedal.
i was wondering if there is any way i could get a new rubber stopper or would there be an easier way to fix it? because its in a pretty tough spot. any help would be greatly appreciated!
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
You could order the stopper from Nissan (Uhhhhhhh no s***) Or just put a bolt and a nut in there for the same effect, thats what I have on my clutch switch. Nissan part# 46584-s0100 (s14)46512-H0101 (S13)
ViolentRunning13
Glue a dime over the hole. I have been driving with no tail lights for at least 3 months. It's totally safe bro.
RustyShackleford
Car: Red Piggy w/Black Meshies
I second that dime thing but I sandwiched two pennies on top of each other and used some JB Weld to hold them all together. I've just had that happen about 2 or 3 weeks ago and it's working perfectly
matt_240sx
thanks for the suggestions! i will try them out!
Two Fowty
Car: 1990 240sx hatch, 1989 240sx hatch
exact same thing happened to me the other week. just get a bolt, and 2 nuts.. one nut for each side of the bolt, when you put it through the whole right by above the brakelight switch.. then just screw the bolts whichever way so you can adjust is easily and get ur brakel lights working the best.
matt_240sx
Two Fowty wrote:exact same thing happened to me the other week. just get a bolt, and 2 nuts.. one nut for each side of the bolt, when you put it through the whole right by above the brakelight switch.. then just screw the bolts whichever way so you can adjust is easily and get ur brakel lights working the best.
What size bolt would I need?
blacksrjdm
Well the shaft of the bolt would have to be small enough to fit through the hole and the head of the bolt would have to be big enough to rest on the sensor side of the hole to push the sensor. Get a nut and washer that would correspond with said bolt and install. Look under the dash and find the hole thats missing the grommet, and eye it up. This is really really simple, and my suggestion right under yours was to put a nut and bolt in there, why didnt you ask then?? Also, two forty there said to put a nut on either side as to adjust the bolt, not ness. The sensor can be adjusted to the pedal, just install the bolt and your good to go. The grommet was just flat, so, no adjustment needed.
Modified by blacksrjdm at 8:03 AM 8/5/2009
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Page 6 of 46 is an illustration on the switch. You can one from other Nissans of the same era. Its a 2 wire plug, a switch with a threaded top, and a lock nut. Take all of 5 minutes to replace. 40 min if your fat like me and need to take out the seat.
http://www.nicoclub.com/FSM/240sx/91-94/BR.pdf
Dont roll with no brake light, no reverse lights, yeah sure, but not brake lights.
blacksrjdm
I believe his switch is fine, just that the grommet that pushes the switch is missing.
matt_240sx
blacksrjdm wrote:I believe his switch is fine, just that the grommet that pushes the switch is missing.
yeah its only the grommet. i didnt put a good title..
thematz
Order one from FRsport like I did. The new stopper seems to be made of more durable material than the old one. Maybe its just me but I don't like to rig things. As for installing it: You'll have to snake your way under the dash. Have someone push the brake pedal down while you slip the stopper in. I went through this a couple of weeks ago. I know how frustrating it is.
http://www.frsport.com/Nissan-....html
matt_240sx
I got it fixed! thanks for suggestions!
adrianfromthecastle
Car: 1992 Nissan 240sx
don't mind the late bump...
but this was the first thread on Google that popped up when I did a search... because my brake lights wont turn off now, after my brother mentioned he noticed my tail lights still turned on..
it just dawn on me that when I was driving earlier this afternoon, i felt this rubber ball looking thing under my right foot rolling around. while driving, i managed to reach under and grab it. I was like, "wtf is this?" and I threw it out my window. FML I had no clue what it was
Eddiemac
Car: 93 Nissan 240SX vert
The best, most durable replacement I have found so far is one of those wide, flat fender-liner/ mudguard screws with one of those metal mounting clips that come with aftermarket speakers on the backside. Works great and will probably never fail again.
safin
LOL^ you threw it out the window?!!
well, old post but could anyone tell me really quick, what color are the wires that go to this switch?.....I don't have the 240 with me.....thanks!!!
bersh240
green with red stripe and red with yellow stripe. but.. looks like all my wires have been messed with soo if u dont c those forget this.
safin
thanks a lot, i think those are it. !
