jcquick »
https://forums.nicoclub.com/jcquick-u25031.html
Sun May 30, 2010 12:22 pm
I'm unsure if you're AFR would be off, but I'm in the same boat as you. I have a broken bolt in my turbo. So, on the turbo exhaust elbow I should have 5 bolts on but I only have 4. I pretty sure I have a leak, since I smell exhaust in the car every once in a while. During idle, I can't feel a leak. If you have access to a smoke machine (DJ equipment), you can see the leak. It's just an idea. I understand how you might not be in the mood to deal with this problem (especially if hot weather is a factor), since you're going to have to take off the manifold, boost tubes and anything else that gets in the way. Good Luck.
