encasemyheart »
https://forums.nicoclub.com/encasemyheart-u1676.html
Tue Jul 01, 2003 4:58 am
It should have 3 belts.
I believe one is power steering/water pump
one is alternator and
one is air conditioning.
I'm pretty sure that's it, so obviously depending on which belt you broke, it could be more or less serious. If the air conditioning broke, big deal, get a new belt and you're set. If the alternator belt broke, you need a new belt, but also your battery won't be charging, so you won't be able to start it after the battery goes dead, which happend fairly quick. If you broke the P/S/waterpump belt, you just may need a new engine. The car may have overheated if that belt broke. But since you drove 2 miles without catastrophic engine failure, there is a large chance it is not the waterpump belt.
So find out what belt it is. IIRC on my 92 the order from front to back (what belt is closest to the front of the car) is P/S, alternator, air conditioner.
Find out which belt broke and replace it. Belts are like $10 or less. If one broke though, it was probably VERY old, belts don't normally break like that, so I suggest changing them all. You will learn alot in the process too.
