Desert Fox »
https://forums.nicoclub.com/desert-fox-u124528.html
Fri Jan 30, 2009 9:05 am
I was searching around and I cant seem to find any info.
I was pulling in to school this morning, and just as soon as I got in the parking lot, I changed from neutral to first with heel toe. as soon as I applied the gas, I heard this huge horrible clunking noise.
I looked under the car, and I could see from the back my right axle had disconnected from the diff. I was told when I got the car it had vlsd, and I know I do now, from seeing the viscious material all over the housing. It looks like the bolts cracked away from the housing on the axle.
I havent been able to find much info about vlsd's in these cars, so i wondering if this one broke, should I replace both axles, or get a new diff, or what. Also, ive been hearing a bit of a grinding noise for the past few days, is this what ive been hearing?
Btw, it was 35 degrees this morning in sacramento. I think that might have something to do with it cracking...
Ill put pictures up after we tow it home today.
