Broken 240 :(
dubbs
yep thats rite it broke :(
i drove the car home from work 3 miles away. it was fine.. just noticed that the car was a LOT louder than normal. So. i notices one tip from the muffler broke off (stock POS) (stock evrything)
anyway.. next morning i wake up for work.. I have no clutch feel wutsoever.. well. basically none. snap it into reverse.. than first than i get to an intersection.. and the car wont shift for anything. i feel like im gonna break the shifter.. so i get it into reverse somehow and drive home.. only like 100 feet.. lol... and look at it the next day
clutch slave cylinder was leaking fluid so i ordered a new one. replaced it. bled the system then tried to get the clutch back
no luck... after doing bout 500 pumps no luck.. so now i towed it to the garage and now waiting for them to look at it.. my question is. wtf do u think is wrong.. and how much am i gonna have to pay outa my sr20det funds... thanks..lol:help
specialkonrd
well, if its not slave cylinder its master cylinderits clearly a problem with the hydrolics. Slave cylinder seems to be common 240 problem but my buddy had his master go once.
you should be able to pick up a rebuild kit quite cheap <$50
bserieshatch69
hi, im the one that replaced the slave. it was indeed leaking and needed to be changed. afterwards, we bleeded from the slave. a lot of air came out but the pedal was still dead. i then began to bleed from the master cylinder (aka black box). there was no air in the lines running to the box. i then bled from the top master (reservoir) still nothing. the only thing i can come up with is that possible pressure plate or clutch has had enough.
specialkonrd
you guys did refill the reservoir right?the clutch should be to the floor if there is no fluid right now and no air. it shouldn't have any springiness.you fill up the reservoir, close it, push pedal in and out (even though it wont have any feel). every few pumps check to make sure reservoir is full and in a few pumps it should be aight
but yeah its also possible clutch has had itmine got ****ed because of my slave cylinder as well
specialkonrd
wait you bled from the top too?i dont remember but i think you're supposed to have the reservoir full and closed and only bleed at the slave
dubbs
we would pump the clutch.. bleed slave then open resevoir to check/fill it.. same thing rite?
Bserieshatch69 ment to say. we bled the 2 boxes underneath the car.. the slave and master underneath.. not resevoir on top. air was comming out at first then just fluid but it didnt work
specialkonrd
so waitwhats with the clutch thoguhliek i said does it just feel like it has no...spring?likeit goes all the way downand u lift it and its all the way upas if it was just a loose pedal?
bserieshatch69
no, when the pedal is pressed fully it sticks to the floor. you actually have to pull it back up with your toe to get it back to the engagement point.
specialkonrd
hrmmwell try thisi dunno how junkyards work where u are but what i woudl do if u wanna try this free anywaysis goto junkyardbuy a master clutch cylinderif it fixes it, great, if not, take it back to them and say its leakin
or if you;re feelin really sneakyjunkyards usually mark the parts they sell with paintso, you take the insides of your master cylinder and switch it with the junkyards, put yours back on, and give the junkyard back the one you bought with your inside parts saying the one they sold u is leaky and you ended up just buyin a new one from dealer
slw240sx
Car: 1990 Ca18det 240sx Hatch
or even better bring a half empty tool box an put the cylinder inside an walk out to your ride set the tools down an go up an pay for say a mirror or floor mats somthing dirt cheap!!!!! i have yet to pay for much other then a seat and thats cause we couldnt get it over the fence with out it breaking !!!
slw240sx
thats cool K car i always keep my doors unlocked an my ignition is broke dont forget to bring your keys!!!!
also i never thought it a problemn , ive never been in a yard that wont let you pick your parts, you make a good point and ill think about that next time im in there
slw240sx
well, K car if they cared they might have raised me right, sorry if i have little to no morals, we all cant be decent people like your self. and i dont really steal anymore ,the state frowns upon people like that an try to put us in jails, really not fun!
dubbs
the garage says i need a whole new clutch assembly.. they wanna charge me 800 for it .. i was like WWWHHAAAAAATT.. it should only cost 450-500 riite????? im callin up other places now thx
Lsnaple
yea im getting new master and slave put on right now. i was gonna do it but i couldnt get the F****** bolts loose for anything.
thats whats wrong. i had the shop check mine to see if that was the only problem, and they called and said i needed the slave too.thats it.but then again, i didnt force it in gear, i just turned it off and parked it.by the way, i was in the driveway when i figured i had a problem.
QUICKFLOW240
Car: racing, cars, chicks, racing cars, racing chicks
dubbs wrote:the garage says i need a whole new clutch assembly.. they wanna charge me 800 for it .. i was like WWWHHAAAAAATT.. it should only cost 450-500 riite????? im callin up other places now thx
Where do you live? I'd be willing to do it for you if you'r anywhere near Baton Rogue, LA. I hate watching people get d!cked by lame a$$ maintenance mechanics.
dubbs
haha no where near.. long island NY
dubbs
this transmission place is gonna do it for 475 so i had it towed there today... hopefully they fix it.. they usin a LuK clutch assembly.. o well
