Broke timing belt stud ! ( no engine damage)
opticnerv
Car: 89' Nissan 240sx SE
I stripped the threads on the stud. I found the right size stud at napa but it's an exhaust stud. After doing some research I found that snapping timing belt tensioner studs are quiet common. So the makeshift exhaust stud has to go. Does anyone have a part number from Nissan ?
Also I think I may have lost the conical washer that goes with the tensioner anyone know where I can get one or if I can get away with just using a normal washer ?
Gabes13
Car: rb20det s13
13073-V5001 is the original number but you may find 13073-Z31001 from an '84-'86 z31 300zx "vg30et" easier
EDIT:
courtesy parts has both
http://www.courtesyparts.com/stud-tensi-p-248414.html
http://www.courtesyparts.com/13070b-stu ... 41970.html
opticnerv
Thanks a lot man ! I've been searching for a couple days already. Did you run into the same problem before too or something ?
Gabes13
Car: rb20det s13
nah, there was a thread about it months ago. I did some research, found the parts, and saved the numbers on my computer. Its funny, finding parts for the 20 are hard, but when you look them up for the 25 and 26 theyre all over the place. Ironically, most of the time, they're the same parts for all the motors haha
chad b.
Car: chocolate chip kouki
Dude, I JUST made a post with an ARP part number for that stud and nut. Why replace it with another pos stock stud that will probably break again?
opticnerv
chad b. wrote:Ok, first off, the p.o.s. tensioner stud that breaks: you can order this from ARP. It is black oxide CrMo.
The part number is AM3.350-1LB. The 12pt nut to go on it is part number AMN12-1. This stud with the nut is gonna be a little long and just touch the lower timing cover. Easy fix, drill a hole through it with a stepper bit. It's at the bottom of the motor, so you'll never see it any way.
Thanks chad I'm re-posting the information you provided here too in case anyone is searching.
chad b.
10-4 my buddy
