Aries »
https://forums.nicoclub.com/aries-u802.html
Fri May 09, 2003 9:13 pm
yep, it broke.car's down until parts can get here Tuesday.
Had a little run in with a black single turbo supra on the freeway tonight. Little roll action went great. We both pulled in to a gas station to talk and decided to do a 0-160 run. Well we pull out onto the freeway and stop (Hazards on mind you) he honks and we both launch. right away I catch traction and take off as he follows closely behind spinning and trying to get into boost. I hit the nitrous and jump about 9 out on him as he gets into boost and tries to pull back. He manages to real me in to about 2 cars out, but I'm holding him off as I shift into 4th at 120. At 150 I start noticing a vibration from under my feet. I hit 160 with his front tires at my door, and let out.
Immediately after letting off the gas I hear POP! And the motor shuts off. I get it re-started and nurse it in to the next gas station with him following close behind.
Well, the intake manifold cracked from a nitrous backfire, the throttlebody blades are screwed, the cold air piping is blown off, and my filter disappeard somewhere behind us on the freeway. Nitrous backfire in the intake. BAD.
Well, I guess I'll order parts in the morning.
