bcar240 »
https://forums.nicoclub.com/bcar240-u13477.html
Sun Feb 27, 2005 9:00 pm
There are only really 2 things that go bad with a speedo (besides faulty wiring, so I guess 3.) One is the speed sensor, this is located in the tranmission, and it basically a metal gear that spins and sends an electrical signal to the cluster. The other thing is the speedo unit itself, this is in the cluster and if you were to look at it is basically a circuit board with a needle on the front. If the sensor in the transmission is bad, that is a pretty straightforward fix, but if it is something wrong with the electical stuff in speedo unit, I would start looking for a new one. On a side note, does your odometer work? (I would think not, but if it does it is definatly a problem with the speedo unit.) There are pretty detailed write-ups on here somewhere about how to replace both the sensor and the speedo, try a search in the 240 tech section.
p.s. I was able to get my cluster out without removing my steering wheel by dropping the steering column, but it was a big pain in the ***.
