Pwnin O'Brien »
https://forums.nicoclub.com/pwnin-o-brien-u136941.html
Sun Mar 07, 2010 1:40 pm
Is this the result from moving your car with the lower links removed?
That half of the driveshaft is called the Birfield (SP?) joint which, as indicated by the manual, should not be disassembled and will need to be replaced in one entire piece, which may result in replacement of the entire driveshaft (unless you replace it from the center bearing back, which could also be a possibility).
