p00t »
https://forums.nicoclub.com/p00t-u5026.html
Sun Oct 31, 2004 8:37 am
If it was just the material seperating from its metal backing it is the pad manufacturers fault. The pad is usually bonded to that surface with a very strong glue. If it has some sort of warrenty, take it back and get the whole rear set replaced! Your rotor is fine, and your caliper is fine. If you cant get a free replacement under the manufacturers warrenty i would strongly consider going with a different brand and replace the whole rear set.
If it was the entire brake pad that came off (complete pad with metal backing), then whoever did the brakes last installed them improperly! They didnt line up the peg on the back of the pad with the holes on the piston caliper.
Your going to have to remove the caliper from the knuckle, then using something (preferably pliers) you screw the piston back in by turning it clockwise. Make it retract all the way in and set the holes to 12 and 6 oclock positions. When installing the pads make sure the pin on the back of the pad seats into the top 12 oclock hole.
Check the other side to see if that one is installed improperly as well. If the pads are worn on an angle you will need to replace them.
