Broke my rear sub frame
574-240sx
Car: Nissans, Toyotas, Subaru
We I noticied I tore my grease boot the other day, so i took time to replace it this weekend. Then i noticed that my rear end looked like it was shoved over 2 or so inches. Then i took a look directly behind towards the differental and seen 3 large cracks that went all the way through. I was pissed. So yesterday I pulled the rear subframe out of my parts car, took 30 minutes, six bolts. Well I hope it goes in easier with a lift. It looks like they broke on the welds and they were rust pretty bad. Nick
APEXi240
Car: 08 Nissan Versa S hatch
I need to remove the rear subframe on my car...There was nothing else that needed to be removed to get it out? Driveshaft, ect??
240_Keyy
Car: '90 240 Fastback
ya you have to remove the driveshaft and the struts and the brake lines
APEXi240
Not too bad...I thought it was going to be worse...looks like I'll eventually be doing that myself.
574-240sx
I put my subframe in. It was only 6 bolts plus 4 drive shaft bolts. Lineing up the old subframe was much harder but I did it all myself in about 9 hours. I ran into alot of little stuff like bad pins, stripped bolt, changing in my VLSD, changing grease boots, and etc. I can get some pics up soon of the damage. Nick
