Broke intake snorkel on girlfriends versa?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
RunningCucumber
Car: 2012 Nissan Versa 1.8L hatch
My girlfriend’s radiator started seeping, so I started replacing it this week.
2012 versa 1.8SL hatchback
While taking off the intake snorkel I broke at least 1 (maybe 2 pieces) pictures included. Can I super glue the circular piece back on?
And lastly does anyone know if this piece is supposed to wiggle like this?
https://imgur.com/a/1gCBQ0o
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
It's okay to glue or tape pretty much any part of the intake leading to the air filter, including the bottom half of the airbox. The worst that happens is you allow a little warm engine-box air into the intake stream. Repairing the top of the box risks letting dirty air past the filter, and anyplace after the MAF you're risking vacuum leaks and unmetered flow.
FYI, Imgur is now popping up a stupid "disable your ad blocker" message. I'll be dipped in s#it before I turn off my blocker for anybody, so I can't analyze your wiggle. Maybe try YouTube.
RunningCucumber
VStar650CL wrote:
Fri Jun 26, 2026 5:03 am
Appreciate it!
I think I got YouTube to work - https://youtube.com/shorts/xJ3DzwwqQgc? ... MLxf68pNEz
My gut tells me that piece is secured by the whole snorkel snapping into the front and resonator bracket
VStar650CL
Technical Expert
RunningCucumber wrote:
Fri Jun 26, 2026 6:58 am
Yep, that worked. Your gut is correct. The red thing in the diagram below is a resonator, you can block the port and eliminate it if necessary. The engine just may "howl" a bit without it.
Return to “Versa Technical Discussions”
