Broke an exhaust manifold stud
TwinTurboFred
Car: 96 S14 , 89 S13
The previous owner of this engine broke off an exhaust manifold stud. I assume I can just "easy-out" the old one...but how do I replace it once I get the old one out?
TrueSlide
Car: Stuff
just buy a stud and screw it in. The stud has two threaded sides.
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
You might have to use a heli-coil after you drill the old one out..But the Heli-coil is stainless steel so you will never strip it out.Sould be pretty easy to do.you might try the ARP studs if you have money to play with..Ill never brake one of those..
good luck with it.
96drifterx
Car: 1996 240sx se
same thing happend to me when i was putting my headers on i just drilled a hole in the middle of the stud and then used an easy out to get it out.
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Well to answer your question....
To install the new stud since they are double side threaded, you take two of the nuts that you would use to put on the exhaust manifold/header and tighten them against each other then thread the stud in.
