Broke 2 A/C belts Need your help
JonathanPrem
Car: 02 Nissan pathfinder 4WD SE
Hi guys,
Really need your help badly. I installed two A/C and both broke off. I installed it properly and it didn't squeal or whine when i started. It worked perfectly fine for about 1hr or so and when i came home and started it up to find out the ac didn't work :facepalm: . It was tight yet enough to be flexible
Anyone know why its ripping off?
I installed it like this
http://www.nissanpartszone.com/componen ... -1420.html
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Prob bad pulley? or the compressor is going bad.
PapaSmurf2k3
Site Admin
I'd keep it loose so it squeals at first, then tighten it up little by little until it doesn't, just so you know you have the tension right. Other than that, check for burrs on your pulleys, or if something is twisted/out of line.
JonathanPrem
Which pulley should i be checking? ac compressor or the idler? Is it common for ka ac compressor to go out? its only got 174km(not miles) on it
PapaSmurf2k3
Site Admin
I would think if the compressor itself was going out (seized up), then you'd be hearing a hell of a lot of squealing, smelling burned belt, etc.
You need to check every pulley that the belt touches.
