****Broadfield's New Interior Mods****
Broadfield
Car: 1992 240sx
KYZAAC wrote:
angelscrx wrote:I was going through the over 600 pics you have on Fotki and I was wondering where did you get the red bolts for your valve cover? thanks
There from http://www.galleryfresh.com , i had to order some soon as i seen them lol
http://www.mynismo.com/products/?id=7213&rsku=24179#
btw, your car is amazing dude
What he said, but keep in mind that the bolts themselves for the valve cover did not come from Gallery. I'm not sure how it is on other SR's, but on the S15 it uses shoulder bolts to fasten the valve cover down. So I had to custom order some stainless shoulder bolts in the specific size for the valve cover. I also had to order longer stainless bolts for the wiper motor, power steering reservoir and a couple other things. The Gallery bolts only come in one length and pitch for each specific bolt size. So I basically put together my own setup consisting of about 80 Gallery bolts/washers then had to swap out about 23 or so bolts with my own.
Caveit77777
Car: 1996 240sx SE
I want to be like you when I grow up haha
Really though your work is on a different level compared to most.
angelscrx
Car: 1992 240sx
btw, your car is amazing dude[/quote]
What he said, but keep in mind that the bolts themselves for the valve cover did not come from Gallery. I'm not sure how it is on other SR's, but on the S15 it uses shoulder bolts to fasten the valve cover down. So I had to custom order some stainless shoulder bolts in the specific size for the valve cover. I also had to order longer stainless bolts for the wiper motor, power steering reservoir and a couple other things. The Gallery bolts only come in one length and pitch for each specific bolt size. So I basically put together my own setup consisting of about 80 Gallery bolts/washers then had to swap out about 23 or so bolts with my own.[/quote]
Oh I see. I was wondering about the lengths of the bolts myself but you answered that for me. I had a question about the DCC LED that you swapped out. See previous post thanks.
Broadfield
Car: 1992 240sx
angelscrx wrote:Wow very nice! Oh, by the way, on the build for Daoud that you are doing you swapped out the LED in the DCC from blue to white and then soldered something to one of the ends? Why switch to white? Do you have a pic of the difference? can you tell us what you used as the replacement bulb? Thanks
They are not white, they are 3mm green LED's. The thing soldered to the end is a resistor. The LED's are only like a 5volt LED. So to use them with a 12 volt feed, you need to wire in a 470 ohm resistor. I don't think I have any pictures with the LED's, but I will look. Daoud picked the car up about 3 weeks ago. I'm sure he has taken some night pics... I'll check with him.
Edit:
I did find a pic I took, but I don't have any before shots of the illumination on the DCC:
You can also see mine, sorta, at the top of this page.
angelscrx
Car: 1992 240sx
Edit:
Good deal, thanks for taking the time to answer my questions. Next time I am in Chicago I will have to try and stop by. I drive down to southern Illinois to see my daughter but al my family lives in Chicago.
Broadfield
Car: 1992 240sx
Cool man, I am about 2 hours south of Chicago.
angelscrx
Car: 1992 240sx
What size battery did you use in your engine bay(dimensions and cranking amps? I like how yours is set up. I have 240s with SRs and my other one has the battery in the hatch but I want to keep this one in the engine bay. Oh and where did you get your battery holder from? Thanks
Broadfield
Car: 1992 240sx
dragonboy240sx
Car: 90' S13 w/ S14 SR(sold), 2006 Mazda 6
I love that battery too... the real question is where did you get the terminals and wires hanging off the side of the battery?
KYZAAC
Car: 92 240sx SR
Broadfield wrote:What he said, but keep in mind that the bolts themselves for the valve cover did not come from Gallery. I'm not sure how it is on other SR's, but on the S15 it uses shoulder bolts to fasten the valve cover down. So I had to custom order some stainless shoulder bolts in the specific size for the valve cover. I also had to order longer stainless bolts for the wiper motor, power steering reservoir and a couple other things. The Gallery bolts only come in one length and pitch for each specific bolt size. So I basically put together my own setup consisting of about 80 Gallery bolts/washers then had to swap out about 23 or so bolts with my own.
where did you order the stainless shoulder bolts from?
King Ranzo
Car: 15 Ford Focus ST
I just have to ask, do you have a speedometer? I see none.
Razi
Car: Moo
His HUD shows his rpm and speed.
angelscrx
Car: 1992 240sx
Thanks Toby! I have a decent stereo in there so I may go up to the 17lb version but this is perfect thanks
Broadfield
Car: 1992 240sx
dragonboy240sx wrote:I love that battery too... the real question is where did you get the terminals and wires hanging off the side of the battery?
I own a car audio store man... I have the stuff laying everywhere! ;)
Probably one of the coolest places on earth...
http://www.mcmaster.com/#
Razi wrote:His HUD shows his rpm and speed.
^^^What he said :yesnod
angelscrx wrote:Thanks Toby! I have a decent stereo in there so I may go up to the 17lb version but this is perfect thanks
Keep in mind, the billet aluminum Braille battery tray will not work on the 17lb battery. Only the 11 and 15.
angelscrx
Car: 1992 240sx
Yeah I saw that about the battery tray which is fine I have another tie down kit thanks
KYZAAC
Car: 92 240sx SR
Broadfield wrote: Probably one of the coolest places on earth...
i agree, thats an awesome site, kind of expensive tho, $6.00 a piece for a M6x1.00 Stainless Shoulder Bolt. does that sound right to you?
where did you get the red belts? i've been looking for a set with no luck, and can ya get any other colors?
Broadfield
Car: 1992 240sx
Sounds about right. Stainless is not cheap, let alone a specialty bolt like a shoulder bolt.
The belts are Kevlar belts from PE(Power Enterprise)
