Just sent you an email.Drakelee wrote:hey, can you email me shipping and payment information. I want to get two 3 3/8's and three 2 1/16's, would they all be able to fit in the cluster? Sorry I would measure my self but I am 4 hours away from my car.
Details man, what do you carry?S13xCrazy wrote:Interested in working someone who distributes the gauges and such? :-P
I'm right up in Wisconsin
Anything and everything...GReddy, Defi, AEM, Autometer, Glowshift, Stri....and so much more. I run a speed and performance store up here in Wisconsin!Broadfield wrote:Details man, what do you carry?S13xCrazy wrote:Interested in working someone who distributes the gauges and such? :-P
I hit you back!FACE wrote:I sent you a pm. I want to a sick setup for a 93 sc300.
Shoot me an e-mail at [email protected] if you want to talk about working together!
Correct, I can do (3) 52mm or maybe even (3) 60mm for that matter in the vent area of the S14 trim piece. I would need you to send me a S14 center dash trim and the gauges. However, you don't need to send me YOUR piece. You could always go to a salvage yard and pick up another one to send me. That way yours stays intact and you are not without it while I do the fabrication.SX APPEAL wrote:So just to be clear, you can do 3 52mm gauges in an S14 center dash vent just like the S13, correct? Do you need the dash vent assembly itself along with the gauges since its a more significant part of the dash in an S14? Thanks
Now your pushing it.SX APPEAL wrote:Hmmm... what about (4) 52mm gauges...
(3) 60mm not a problem.... (4) 52mm not going to happen comfortably, at least not in my opinion.SX APPEAL wrote:Haha I'll wait for the verdict tomorrow...
What gauges are you wanting to do exactly, brand and model? That way I can look them up and what the exact outer dimension is. When they say 52mm gauge, that's the size of hole it mounts in. So the outer diameter is even bigger. Or if you already have them please measure the overall diameter for me.SX APPEAL wrote:Is there any kind of setup you could do involving letting one or both of the outside gauges hang over the edges? I'm open to trimming the dash slightly. If not I understand and I'll stop cluttering up your thread lol. Thanks
$200 if I can do the OEM turn signals. I have not incorporated OEM signals with an S14 yet though... only S13. So if it can be done $200, if not, then $145 and I would use aftermarket indicator lamps of your color choice for the turn signals.Speckid4 wrote:How much for an s14 cluster with 2; 3 3/8" Autometer gauges and with 2; 2 5/8" autometer gauges. Also with wet sanded plastic and oem turn signals?
Thanks, Jimmy
I would need your gauges and the entire S14 cluster.Speckid4 wrote:If I could get any sort of turn signal indicator thats fine. The aftermarket indicator lamps would be fine with me. These look awesome and I'm short on time so looking forward to doing business in the future. What would you need from me besides the gauges?
I can make whatever you want.... I usually just refuse to do the work if the customer wants it half-a**'d or the customer wants something that I think is going to look aesthetically bad. I'll send you an email and we can discuss pricing... it won't be cheap, probably several hundred dollars to do both of those pieces.HxC_Nismo wrote:i was wondering if you could modify my a-pillar to have 3 gauge pod, because the autometer one does not make a 3 gauge pod and i would like it to be molded into my pillar instead of mounted with screws. and also i would like to modify my stereo plastic trim and delete the cig lighter and ash tray to fit 2 52mm gauges. what would you charge me to do this? email me at [email protected]
It's funny you ask, I am completing an S14 shroud very soon for a customer... this is where I am at now. I basically need to do the finishing work: final sanding, texture, paint etc. You can also check my blog for some build info on it, however, I have not discussed the fabrication of the center section on my blog yet :n00b240 wrote:Ive been procrastinating asking this for a while, but on the S14, do you do a custom fab of that center console area, where the A/C and radio trim are? With a mounting system where the A/C vents go? Ive got one of your alpine units that Im pretty happy with in the radio, but now looking to get some gauges in the A/C vents, replacing a\c and radio trim.
Thanks in advance
It totally depends on how you want the gauges mounted. The way they are in that piece is about as difficult as can be. I had to cut the original opening larger, which meant that I lost the OEM round over that led back to the vents. I rear mounted a base plate then reformed the entire round over. Everything was hand shaped and sanded. So to duplicate that with just the gauges is $300. If you simply want that area molded over solid and the gauges surface mounted, then $200. If you want that area molded over solid but with flush mounted gauges then $250. If you want that area molded over solid with angled gauges then we are back up to $300.HxC_Nismo wrote:how much would you charge me to do just the 3 gauges on the center peice like the in the above post^^^^ and thats it cause i think it would be nicer to have. let me know highly interested. [email protected]
Sorry man, I'm not on here but a couple times a week or so. I'll send you an email.HxC_Nismo wrote:still waiting for your response
