nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Tue Jan 22, 2008 9:10 am
1. No. Don't spend the extra money. Because...
2. It's very easy. Lift the car up, a couple of rubber hangers to deal with, two bolts to get the old one off, then 4 bolts to get the new one on (should be in two pieces).
3. An hour MAX, even for a true car newb. 15-20min, including jack times, if you're familiar with the parts.
You shouldn't needing any welding or adjustment. Worst case scenario one hanger is a little bit off and it's $50 to re-weld it at your exhaust shop.
