Brining my Swap together. Input Please!
BirdOfHermes
Car: 93 240sx w/rb20 swap
Alright first of all I'll explain the situation. I have a 93 240sx with a rb20 already swapped in, I bought it this way. I have already purchased a rb26dett with the rb25 transmission. I'm buying the Mckinney mounts, downpipe, and driveshaft, I have the complete wiring harness uncut. Basically I'm just trying to get the engine in and get it running stable. I'm in the military and I only have 2 weeks to complete this swap, fortunatly, I have a full shop with a forklift at my disposal. What I need to know is, are there any other basic things I'll be needing for this swap. I'm planning on using a Spec RB26 stage 3 clutch for this and matching flywheel, will that work with the 25 transmission? I want to make sure everything lines up. Should I replace the water pump while it is out? I have been doing alot of reading about the subject for the past year, and I'm just trying to be meticulous. I appriciate any help given.
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
as long as the clutch is for the rb25det transmission, a new slave cyl for the transmission would be a nice add. good luck
BirdOfHermes
Thanks I appreciate the input, it should all go smooth, I have a big shop with all the tools I will need.
