okay i think i found the problem is being able to change the settings on the safc? quote:
"as far as i know it should work , its a hot wire sensor type 0- 5 volts output and there is map for it in safc so soon im going to try to do it " unquote.this is from one of his post
zerothread?id=162047
i have a safc NEO. never seen any map change ability? he has a safc2? does any one know how i can change the map settings on a NEO?
