Skibane »
https://forums.nicoclub.com/skibane-u40096.html
Thu Sep 14, 2006 8:55 pm
"Backwards" means inserting the bulb with its contacts rotated 180 degrees from the way they should be. This would apply power to the brake light filament when the running/parking lamp filament should be powered instead, and vice-versa. The base of the bulb is "polarized" so that wrong-way insertion is supposed to be impossible, but it doesn't always work perfectly...
There are no separate "left" and "right" side bulbs - they both use the same bulb part number, and can be used interchangeably on either side.
