GaNITE »
https://forums.nicoclub.com/ganite-u27713.html
Tue Apr 12, 2005 7:24 am
Most head units have outputs that are designed for driving 2 to 4 speakers. These outputs provide the audio output power to drive the speakers. The power from a high power head unit is actually limited by battery voltage to about 20 watts per 4 ohm speaker. All of the manufacturers that say their head units can produce 30 or more watts of real power are full of ****. On "high power" units, the internal audio amplifier will most likely be damaged if a speaker output wire is allowed to contact anything except a speaker terminal, even if the volume is not turned up. make sure that there is no power to the h/u when making any connections.Most of the head units which are damaged, are damaged due to incorrect connection of the speaker output wires. This is especially true with "high power" h/u's.It IS POSSIBLE to bridge your h/u speaker level outputs, I've seen it done.That said, I'd recommend you don't. If you TRULY desire proper SQ, go with an external amp, quality components(not polk) such as mb quart, boston acoustics, jl, focal(which all come with external x-overs, by the way)....etc, and some QUALITY cables/speaker wires.<--most important step!! that's where your sound is coming through, after all. I also agree in upgrading to the cd400. i have one in my q and the quality for dollar really can't be beat.(plus it's got a 24 bit DAC for under $300!) as for the fosgate.....do you know anyone who would buy it?? just a thought.
good luck in whatever you decide to do......i hope i helped somewhat.
