codyace wrote:Sell the BC's
Get JWT S3 cams. They are true 'drop in as OEM' and go cams. They'll make 15-20 more whp than the BC's and be cheaper in the long run (no need for cam gears, no need for springs).
But to each their own. There's a reason the JWT cams always make more average power, more peak, and more torque...it's because they are actually designed/researched/tested...unlike the chinese copycats...such as BC.
EDIT: Tomei manifold will hurt power everywhere for your turbo, OEM would have been best. Sell it while you can. Sure stock doesn't have the bling factor, but who cares.
Edit: If you're modding on a budget, Fuel/TUning come first, then power. Also it would not be a bad idea to get a second 'beater' car...god only knows how many peole have modded their 'turbo car', not had it work, and not made it to work/school the next day.
Thanks codyace! I def like your input, but it should be known that
A. I never bought the cams, havent even torn down the motor yet, just was looking for info
B. My 240 is my weekend driver/hobby, I have a 01' Ranger as a DD and a company van for work...I would NEVER have a SR swapped 240 and expect it to be a reliable DD, (even though many people do) it's just not practical, especially in Ohio.
The more I read, the more I start to wonder about the quality of BC cams...I have obviously heard of JWT but honestly never looked into their products or R&D. I will def check into them now knowing that! I also thought BC parts were made here in the states?! Oh well...I would however, like you to elaborate more on how the Tomei will hurt the powerband "across the board" for the turbo and have absolutely NO benefit. I realize that I could have honed the stock manifold and also had the outlet ported to match the exhaust inlet side of the turbo, but the quote I got to have that done was almost the cost of the Tomei when I got it on sale. And the way I look at it, later on when I DO supporting mods and possibly go to a larger turbo, the gains/performance of the Tomei will surpass that of the extruded stock manifold. I've included this vid I found some kid put up of how quick his t28 spools up with the Tomei:
http://www.youtube.com/watch?v=8GoOOG1B-6o
^ not like that is some kind of great vid or anything, but it does show it in action, and it certainly goes into boost way quicker than my t25 and stock mani.
Also, I def hear you when you say fuel/tune first!!! It's not really a budget issue, I could drop the coin now and just be done with it, but I'd rather just slowly put some funds aside over time and then do everything. The only reason I went with the s15 t28R is because I got a great deal on it, it's brand new from Nissan, and my stock t25 is on it's way out and I didn't want to rebuild it. I know I'm upgrading to the Tomei manifold (which may seem pointless to people) but I figure that the t28 on a wastegated 7lbs of boost will not be any more different than the t25 to really cause issues with the stock ECU, and isnt out of the limits of the stock s13 SR injectors or MAF...am I wrong?? please let me know!
