Got the brembo rotors on PBR pads new bearings and seals. Bedded them in early this am while there was no traffic. This thing is smooth quiet and grab like a drunk in a strip bar. Well worth the 140 bucks, things went smooth. Found a trick for breaking the bolts on the rotors loose. drop the hub into back side of rim and let the studs hit the rim holes. That holds them in place with no spin while breaking the rotor bolts loose. Did the same to put them back on. Took all of 2 hrs and it is a major improvement. If you have to do brakes go to IRP.com and get the brembo replacement(not slotted or drilled just stock replacements) 37 bucks a rotor and much better than stock or napa autozone s***. It is worth it and if you order pads and get to 100 bucks shipping UPS ground is free. Took 2 days to bama from penn. They are in Cali but have warehouses around the states. I highly recommend the parts and IRP. Here is a link to them, great place great service and great prices.
http://performance.importrp.com/brakes/ ... 10043.aspx
