Brembo Replacement Rotor and Hawk HPS Brake Pads - (Standard Brake Package)
Member area: Post up your ride and the modifications to date
TJMaxx98
Car: 2004 G35 Coupe / 2008 FX 35
04 G35 Coupe AT (Non Brembo brake package)
Brakes - Brembo Replacement Rotors and Hawk HPS Brake PadsInstallation difficulty - Medium Install time - About 2 hours at local ShopCost - approx. $288 plus 120 for the installAdvantages - Much better braking with the standard brakes, OEM pads and rotors would grab, not the greatest pedal feel either. Much better now and very low brake dust!!!Disadvantages - None yet...
adren77
Car: 2004 G35 Laser Red Coupe 6MT
I'm a little confused if this is Brembo or Non- Brembo since it says "Brembo replacement rotors" and then it says "Non Brembo brake package"
TJMaxx98
It's the Brembo Brand rotors for the Standard Brake Package, not to be mistaken for the awesome looking Brembo calipers found on the 03-04 Coupe that has the 6MT. I just bought the Brembo rotors for the standard brakes, does that make sense?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
TJMaxx98 wrote: OEM pads and rotors would grab, not the greatest pedal feel either. Much better now and very low brake dust!!!Disadvantages - None yet...
So "grab" on intial application is somehow bad?
Low pad dust means wither the rotor is wearing or the pad is harder, neither of which is good for brake life nor intial application cold stopping distance.
Two myths of uniformed consumers is that all season tires really are and brake dust is somehow "bad."
bgwilliams1977
Car: Infiniti G37x
i agree with both statements. The Hawk HPS break pads are awesome. The produce high breaking power with low dust emission, but keep an eye on the rotors. This break pads, since they are street racing to track use pads, will tend wear the rotors. Nothing to be concern, since the rotors will last approximately the life span of the break pads, even half the life of the second set. One good thing is that you will not feel breaking vibrations, because the rotors are always gonna be grinned.
Return to “G35 and G37 Modification database”
