brembo brakes?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
dolamite
Im looking to replace my stock rotors and pads, but the brembo pads and rotors say that they are for use with a "brembo" setup? What does that mean? If i buy just the Brembo pads and rotors, they wont work?
dolamite
is this a good deal and brand. They have a set of front and rear slotted rotors and ceramic pads for 214.00 on ebay. The brand is PosiQuiet.
dolamite
sorry, they are semi mettalic brake pads, not ceramic
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
If you have a Sedan and didn't upgrade to Brembo Brakes, then it won't work for you. The 03-04 coupe and 03-04 track 350z came with brembo brakes.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
brake pads/calipers/rotors would all be different sizes
C-Kwik
RED_DET wrote:If you have a Sedan and didn't upgrade to Brembo Brakes, then it won't work for you. The 03-04 coupe and 03-04 track 350z came with brembo brakes.
To tack on and further clarify, the 03-04 coupes with the 6MT were the only G35's to get the Brembo brake set-up.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
