Brembo Brakes fail at 17,000 miles?
Nissan 350z / Nissan 370z general community discussion forum
bennyz
Car: 2006 350 gt
2006 350 gt making low grade noise in front dealers says rotos and pads shot cost to replace rotors and pads $1385.00. I drive it easy no hard braking. dealers says he see's this alot even at 15000 miles He says warranty won't cover it because its a wear and tear item?
bennyz
Car: 2006 350 gt
has anyone with a 06 z had a similiar problem? The dealer says its common?
C-Kwik
The OE Brembos tend to wear out pretty quickly. I replaced a set at about 17,000 miles when I had my G35. The rotors tend to be pretty soft so they are usually below the minimum thickness by the time the pads need replacement. Stillen and Stoptech make some nice 2-piece replacement rotors that are cheaper than factory rotors.
CABhc4life
Car: 2006 350Z
I'm approaching 20K miles on my '06 Z that I've had for approximately 1 year. The tires and brakes are still going strong and probably will be for another 3,000 - 5,000 miles. No complaints here.
samej82
Car: 2007 Nissan 350z
No problems here either... just curious though do you guys have the manual transmission?
bennyz
Car: 2006 350 gt
Thanks for the tip. The dealer/service manager@Buena Park, Nissan/CA was very helpful. He agreed to turn the rotors and replace the brakes as "goodwill". It cost me $164.00 for labor. He said the warranty for brakes is 1 year/12,000mi. I will check on the Stillen replacement rotors. The tech said I cant turn these again.
bennyz
Car: 2006 350 gt
Automatic
flyguy2618
Car: 06 nissan 350Z
I have an 06 Z, its a 6 speed with about 15,000 miles on it and i havent had any problems with breaks or tires there both still goin strong. Actually the whole car is goin strong nothing wrong at all.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Seems it worked out well this time. But in the future, don't let the dealership "rape" you on a brake change. I would have laughed in his face if he quoted me almost $1400. Why couldn't the tech turn rotors with 15K miles on them. Sounds like two people FOS @ that dealership.
flyguy2618
Car: 06 nissan 350Z
Like i said before i have an 06 Z with about 15,000 miles on it and so far no break problems that i can tell. But i was just wondering when should i need to change my break pads and how can i tell when it is time without anything else like the calipers getting messed up?
bennyz
Car: 2006 350 gt
Mine made a low grade noise when slowing kinda like tire noise. The reason my estimate was so high is because I have Brembo brakes and the dealer wanted to replace the rotors $400 each. You should have thm check your brakes next time you take it in for service. I will need to replace the rotors next time as they cannot be turned again. Ant ideas on where to get rotors for less than $400 each?
RED_DET
Vendor
2011 Infiniti G37x
http://www.g35parts.com/9083/o...40_53
Front rotors 75ea Helluva lot cheaper than 400. 139 for front pads from them as well. About 1hr of your time to change the front brakes and you saved yourself about $1100. You could changed all 4 brakes out for new rotors/pads and save yourself $850 as opposed to messing around with the stearlership.
bennyz
Car: 2006 350 gt
thanks but I need the Brembo rotors since I have the Brembo system
bennyz
Car: 2006 350 gt
is that picture your Z? If so how do you upload a picture of your car?
nismofly
Car: 89 Nissan 240SX Hatch
bennyz wrote:thanks but I need the Brembo rotors since I have the Brembo system
http://www.g35parts.com/9083/o...d=633
also i wish i got 17,000 miles out of brakes, i should get z33 brembos for my s13
flyguy2618
Car: 06 nissan 350Z
Hey Bennyz that sounds good ill have them check that out next time i bring it in. But no thats not my car mine is silver i just found that picture on the internet and liked it alot. But i think you can put pictures of your car in that spot i just forget exactly how to do it, i think you go to my profile options and then go to images or whatever that area is called and then just upload a picture of your car off of your computer i think it can be any picture it just has to be under a certan size but im not really sure so you might wanna check with someone else if you get confused.
bennyz
Car: 2006 350 gt
06 350Z just bought a new air filter and put it in. The old one seemed to have some sort of oil or lubrication on it? Am I supposed to apply anything to the new air filter?
nismofly
you sure the old one wasnt reusable? normally oil means you can just hose it off, apply fresh oil, and throw it back in
i dont know z's well enough to know whether the stock one is reusable or not, though i cant imagine it would be
RED_DET
Vendor
2011 Infiniti G37x
are u serious....
that is for the brembo equipped 350z/g35c... $74.99 ea.
bennyz
Car: 2006 350 gt
Sorry I must have been inbibulating the first time. thanks for the SOURCE, that will save me big time in the future! I want to learn how to replace rotors and brakes myself. Do you know the level of difficulty?
RED_DET
Vendor
2011 Infiniti G37x
If you can pick out the right size socket and turn the ratchet, you will be done in a 1-2 hrs.
mrgoboogi
Don't pay that much for BRAKE SERVICE there are far better brake rotors and pads for lot cheaper and these are brand name ROTORS and PADSgo check out this web:
http://images.google.com/imgre...a%3DN
That page is directly linked to 2003-2007 TRACK 350Z BRAKES which are equipped with brembo brakes.
Return to “350z / 370z Discussion”
