Brembo brake noise?
Nissan 350z / Nissan 370z general community discussion forum
glacier
My GT comes with Brembos on front and back, and every time I brake, the moment the car stops / goes, the brakes makes quite a audible noise.
I was told by Nissan Service, that this noise is due to the metallic pads that's used.
I don't fully believe in that.
Can somebody please explain / enlighten?
BusyBadger
Car: '92 Nissan 240SX
'05 Nissan 350Z
'13 Nissan Juke
I've got Brembos and they don't make any noise at all.
Are you just describing the sound over the phone to them or you actually taken it in the to the shop and let them hear it for themselves?
xjmxstac
Car: 2003 nissan 350z track edition
my z's brembo's don't make the sound, but my friend's sti does. The z's in canada probably uses a different brake pad compound than the ones in the U.S.My friend fixed his problem by using hawk brake pads. Less noise less brake dust. Good luck!
glacier
Brake dust is another issue that I haven't talked about yet------stock Brembo makes tons of dust all overth wheels.
So I guess getting Hawk pads is the way to go?
I am not all that familiar with brake pads-----are there different sizes / shapes (types?).
I can't imagine that they are universal.
Any input would be appreciated!
R350Zz33
Car: 2008 350z enthusiast
just google 350z brembo brake pads and take ur pick.
xjmxstac
glacier wrote:Brake dust is another issue that I haven't talked about yet------stock Brembo makes tons of dust all overth wheels.
If you're planning to purchase this in the store, they should be able to give you exact fitment for your car. Online is just as easy, it will ask you for your car's year, make, model, and trim.
glacier
Thanks for the info guys!
Are Hawk pads better than stock Brembo pads?
I want better stopping power, with acceptable level of noise and dust.
xjmxstac
In many aspects, yes. http://www.hawkperformance.com...c.php
_b.jaye_
Car: '03 350Z
im not sure how you got in mind of runnin the car, daily driver or track, but id just go pick up a set of semi-metalic pads at autozone or advanced if you just got a daily driver (no complaints about the wearevers on mine).... no pad will give you better stopping power... just better fade resistance properties & wear / noise characteristics. and a smoother application of braking force
glacier
Thanks people! I must admit this forum has been extremely helpful so far!
BusyBadger
'05 Nissan 350Z
'13 Nissan Juke
Racing Brake.com
Richie, you need to look there too. Plenty of alternatives to the OEM Brembo package for much less $.
cookie.monster
Thats strange Glacier. My Z with stock Brembos made noise too--especially during low braking.
Googled around and it seemed the Nismo-R tune pads were highly recommended. So I picked these up along with the Brembo slotted rotors. Didn't go with the cross-drilled as they are prone to cracking.
Just had both fronts and rears installed a couple of days ago.
Until everything is broken in, I don't expect all of the noise to disappear right away. Whatever result can't be worse than what I was hearing on the stock brake setup.......
Return to “350z / 370z Discussion”
