HighRoller91287 »
https://forums.nicoclub.com/highroller91287-u88087.html
Fri Feb 01, 2008 5:39 pm
When i brake, sometimes the rear pads make a grinding noise. about a year ago this same noise was comin from the front brakes... brought car to dealership, the front brake pads needed to be changed and one of my rotors had deep grooves in it. they said it had to be replaced along with the rotor on the other side. Dealership tried to charge me about 3gs for the job but luckily after raising hell they covered the rotors under warranty.... Anyway this grinding noise is beggining to occur from the rear and i need to change my rear brake pads, im trying to avoid the rediculous prices from the dealership and i have a couple questions.....
the pads from the dealership would run me about $120 - can i find brembo brake pads anywhere else for cheaper??
are other brake pads that are compatible w/ the brembo system better/ good enough to buy?
the dealership said i would have to buy shims which cost $70 - should i have these shims already? ; what is the purpose of these shims and are they necessary??
is it recommended to resurface my rear rotors when i change out the pads?
thanks for the input!!
ps: where can i get a trunk cargo net for cheap??
