RedSVTFlareside wrote:
I prefer EBC green stuff or Hawk HPS for the street or autoX. For the track, its going to be nothing but hawk HT-10 or equalivant from now on. I am overheating the HPS and HP+ pads.
Fluid is also important. I am still cheap and use the discount auto store's generic DOT 4 fluid. I need to start using the super blue or motul or something with a higher dry boiling point and flush more often.
I have a few racer friends that won't touch anything made by EBC with a 10' pole, not sure why, but I never hear any one speak highly of their products.
I didn't care for the Hawk HPS, I didn't notice much difference over stock with them. But I know lots of people that speak highly of the HP+, and Blues, their only complaints are corrosive dust (and rotor life on the blues). BTW, HPS aren't meant for track use, I almost found that one out the hard way. Nothing like a little pad fade to make ye' olde butt pucker up. I'm kind of surprised you are over heating the HP+'s I though they're a track pad? I know of at least one mustang owner that runs them on his car for track days, but he also runs brake ducting. Maybe you could see some benefits from some as well.
I think most HPDE's recommend a new fluid every year. True blue is about half the pice of Motul, and is less Hydroscopic (or so I've been told), but it has a lower dry boiling point. You should also replace the fluid if you boil it.
You might also check out Carbotech brake Pad/s a lot of Spec Miata as well as track junkies in general run Carbotech pads I loved the ones I had on my 240, every one else thought they induced too much front brake bias, but I was used to it, and drove around it. When I upgrade the pads on my miata, thats what I am going to. They are expensive (I paid 110 for a set of front track pads), but IMO they are worth it.
http://www.ctbrakes.com/about.html
Modified by cracker at 9:01 PM 5/9/2007
