Drilled rotors have a history of cracking under high heat. If you want to go for an upgrade, go slotted. Just keep in mind, that when they wear out, you can only replace them--not resurface. So that may not be economical.
chmercer wrote:just get the brembos without any machining done on them. it will be much more likley to crack and will not perform as well. PS if you warped your rotors you should change your pads as well, that will lower your chance of warping another set of rotors.
new pads are a good idea, since the pads you have now have become altered by the warped rotors. New pads to new rotors will assure that they'll get seated/broke-in properly. I recommend ceramic pads: quiet, relatively dustless and much better bite than regular metallic pads.
i recommend brembo blanks as well.
