float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Sun Nov 11, 2007 8:58 pm
As others have said, a catch can on the exhaust side might help.
But I also know from experience that if your rings are worn and you get into boost and then decel, the gases will get sucked straight into the intake from the intake side valve cover.
To really do it right, you'd have to have 2 catch cans, or get creative with your plumbing.
We've covered a lot of possibilites in the FAQ.
My plan would be difficult with a MAFS setup, but do-able. I'm using a MAPS setup, so it should be quite simple for me.
I'll try and explain what I'm thinking, but I don't know if it will make sense.
First off, let me explain how the system works.
There is a tube, on the top of the oil filter seat that runs under the intake manifold, and then up to the intake side valve cover gasket. That tube's purpose is to move crankcase fumes up to the head so that they can be drawn back into the intake system via the exhaust side tube going into the suction side of the turbo, and via the intake side tube going through the PCV valve (just a check valve) and suction in the intake. So that they can ultimately be burned inside the motor.
If the system isn't hooked up properly, especially if it's not hooked up at all, the gases build up in the crankcase and start finding other routes to leave the motor. Commonly they will cause the dipstick to blow out a little bit. But they can also come up the oil drains going through the block and the head. This means that the oil can't drain back down like it should and can cause problems at high revs and boost.
So here is my idea.
-Remove the hose on the intake side valve cover that connects the valve cover to the tube. -Plug the tube in the valve cover that goes under the intake.-Install air filters on both valve cover fittings.-Connect metal pipe under intake that used to go to valve cover, to the inlet side of the catch can (if it has an inlet and outlet, otherwise it doesn't matter).-Run a hose from the suction side of the turbo to a check valve of some sort. You want the air to flow only towards the turbo. -Connect other side of check valve to a T with a hose.-Connect a hose from the PCV valve (basically a check valve that only lets air go into the manifold ) to the T. -Connect the last opening on the T to the other side of the catch can. -Voila! You now have a PCV system, that constantly draws in fresh air and the air flow only goes from the top of the motor down, so the oil flow can't be impeded.
Remember, this only works on a MAPS equipped car.
On a MAFS car, you could replace the air filters with hoses that connected to the intake tract somewhere, but I'm not sure where. I would think you would connect them to the inlet side of the turbo so that you aren't pressurizing the crankcase, but IDK if that will work or not.
Does that make any sense at all?
