Breather Filter? kinda worried
badbob2121
Car: '92 Nissan 240SXS13 Hatch ELLIS JUAN
'12 Ford Mustang GT RTR
i recently bought my s13 w/ a s13 sr20det, and i was scrolling through some other forrums and noticed a comment not to run a breather filter on the valve cover, and that it can build up pressure.. well i have done some research and i kinda in a rut...
heres a pic of my setup...
know correct me if im wrong... a oil catch pan is what i need, please any help would help out, thanks
Sleeper_RMS13
Car: 91 FB W/Blacktop SR
You can either get a oil catch can or take off that breather and get some heater hose and run it into the intake. Because that T valve really needs a good vacume source.
MrSoutherland
Car: S13 - Sr20
In the picture that you provided there already is a catch can hooked up. It's the black box looking thing above your exhaust mani. You need a hose where the filter is going into the intake tube after the MAFS.
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
While you're at it OP, shorten that ground wire you have mounted to the rad support by the cold pipe. Main grounds need to be under 18" if possible.
