breaking up???
alysesparents
Car: 91 240
hello I was wondering if anyone heard of this problem or have experenced it under full throttle in second gear and up at about 6k rpm and above my car sputters and backfires it started when I got a aftermarket intake manifold so I got iridium plugs they are gapped at .30 thinking I was blowing out the spark and it still does it any suggestions would help alot
Joe
check your ignition timing and make sure you dont have any leaks around the IM. could be a boost leak.
BoostFab
Car: S13cp, S13fb, S14z
i'm a fan of iridium; try different set of spark plugs (try NGK BCPR7ES,pn#3330 ) and gap your spark plugs to 0.8mm;
alysesparents
Car: 91 240
I checked for boost leaks and i didnt find any and I tried a set of hotter copper plugs and it did the same thing
boriquaS13
Car: 92 240sx
R you leaning out? Not enough fuel?
alysesparents
Car: 91 240
I dont think so the only mods that i have on the motor is walburo fuel pump fmic and new intake manifold I wouldnt think that would lean me out I thought that it was an ignition problem like I was blowing out the spark or mabey that my maf isnt able to keep up or tps sensor needs adjustment and when the engine sputters it smells like fuel
Blown240sx
Car: 1996 240sx
I know my buddies have this problem a lot with thier RB25s and it mostly due to the stock timing map in the ECU.
rustbucket
Car: '90 s13 RB25DET SII
I had the same problem, had to adjust the timing.
Carl H
its called a revlimiter...stay away from it.
BigPar
this is not rev limiter. A lot of people have this problem. And basically the way to cure it is leaving stock boost, or using some sort of managment of fuel and air. Standalone of course being the best way to cure it.
