JNM240 »
https://forums.nicoclub.com/jnm240-u395.html
Sun Apr 15, 2007 4:05 pm
Basically, what i did was start it for the first time, let it get up to operating temperature while looking for leaks and trying to make sure the small ammounts of smoke coming off the motor was from fingerprints and grease burning off, and not exhaust leaks. Once up to temp, turned her off, checked all the fluids once again. Started her back up, waited, set timing and idle, drove around the block. Then i just took it easy for a day or two. I changed my oil after the first 50 miles (i was using the cheapest oil and filter i could find), then again after 500 miles. After that 500 miles, i let her rip. Hope this helps.
