Breaking In Engine new Oil???
jrphiladelphia
Car: 2007 G35 Coupe 6MT
After much anticipaiton, I finally took delivery of my new 2007 35 Coupe 6MT. From your experiences, whats best way to break in this engine. Have also read that I should change oil imediately. Let me know what I should do. I appreciate your advice in advance.
Thanks,
JR
gjim0535
Car: 2005 G35
basic break-in.... don't drive same speed for any length of time first 500 miles. vary your rpm's on freeway, don't take it past 5800 for first 500 miles.change out oil after first 500 and your ready to rip it up....post some pic's and congrats on your new G!!!!
soul_hfk
Car: 2010 G37xS---08 QX56
welcome & congrats
oh and pics
jrphiladelphia
Thanks for the advice. I will put some pictures up here later in the week. If anyone has any other I ideas, please let me know.
JR
szh
Car: 2018 Tesla Model 3.
1. Change your oil and filter at 500 miles.
2. Then, change your oil and filter at 1500 miles.
3. After that, regularly change your oil and filter every 3750 miles (or less, if you want). Without fail on the mileage and/or 3 months go by!
4. Use Dino oil for sure for the first 7500 to 10k miles. Castrol GTX 5W-30, Chevron Supreme 5W-30 are both good oils for this, although almost any good oil is likely to do fine. You can vary the formulation to 10W-30 or 10W-40 weights depending on your location and temperature conditions and season of year, etc.
5. Consider changing to a good synthetic after the initial 10k miles. I use Mobil 1 0W-40 with happy results. But, contrary to some people, changing to a synthetic, albeit a good thing to do, is not mandatory so long as you do regular oil and filter changes.
6. By the way, use the OEM Nissan/Infiniti filter - some of the other after-market ones may not be up to snuff (an exception: the Mobil 1 filter). The OEM filter is inexpensive enough from http://www.everythinginfiniti.com - I get the filter and drain plug crush washer (always replace this at oil change!) from them, in six packs for a very nominal cost.
Z
