Thanks, i've read so many different ways to break it in my head is spinning lol. New build and you only get to break in the rings once so I want to do it right.asoomal wrote:For the first 20 minutes, do not let it idle. Rev it gently from 1500-3500. Even when bleeding coolant.
Then do an oil change, change the filter and pour in oil with high zinc content. Do not run synthetic yet.
Do lots of mid range pulls and engine braking, 3rd gear should do fine. Do not get close to the limiter, drive it rather aggressively but don't beat it.
After 50-100 miles, do another oil change, and repeat, this time taking it a little bit higher. Remember to change the oil filter too.
Do another oil change at around the 500 mile range, and other one at 1500 mile range, check the oil and see if there's any sign of wear.
After that, it should be safe to use synthetic oil.
asoomal wrote:Are you running aftermarket pistons with their rings?
If so, you could also ask the manufacturer of the rings and ask them how to break them in. Different kind of rings require different procedures.
hay bro...might i recomend a book " How to Blueprint your engine" it's an "SA" brand book found in most book stores...it will clarify things a bit when it comes to Critical things like the hone and cross hatch pattern...lexcrob wrote:as for cross hatch pattern most are 45 i guess some ive seen are more like 45 and a 60....
some rebuild books and crap recommend trying to replicate whats at the bottom of the cylinders (factory angle)
Really i guess it comes down to the rings. I guess the above method would be ideal for oem rings. If using aftermarket id say try contact them just to verify what they recommend. Honestly its not a big thing anyways give it a couple up and downs with a honer lubed up with wd40. The only other important step is you must CLEAN the $hit out of the cylinders when your done with "perfered hot water and soap. No degreaser or citrus just straigh ole ajax, dawn etc....
I did some reading some where about hone types. I guess the type you buy at like advanced auto with the springs and stones is actually a "glaze breaker" and will remove material making bore bigger. The little spiral ball type will not remove much material at all..... Then there are machine shop set ups with same stuff as the breaker but they normally have bunch of stone grades to match rings and what not.
^ thats really all it said<-- who knows?
lexcrob wrote:Picked up ur recommended book. WOW very good read good tip. Im actually about to start a ka24de build up. Original intent was supercharger but the $ is saying its gonna go budget to the max NA. < like make all my own gaskets budget LOL
My plan is to put this ever growing myth that streetable roughly 200hp ka24de is just that. Realizing that there is almost no dyno graphs NA for ka's and that cam timing has never really been addressed. < --- look into degreeing that ever popular exhaust as intake cam swap <<<<some are making unbelievable power 176
(even import tuner made a descret claim power is to be made)
