V8slayr »
https://forums.nicoclub.com/v8slayr-u126031.html
Fri Jun 26, 2009 8:20 pm
All good advice. Just make sure to load the car. Drive up hills in a high gear, varying the load. I drove mine for about 300 mi. just going 1/2 - 3/4 throttle up hills and such and then began to boost it after that. I was boosting about 15 psi for a few hundred miles, shutting the car down no later than 6K. I waited until the car had around 700-1000 mi. on it before I started doing full RPM pulls. Also, change the oil a few times in that first 1000 miles, and use regular oil as paulie said.
