breaking 10s
rcodea
in your honest opinion, how much would it take to get S14 with RB25DET into the 10s? i am thinking about a wide-*** 600 on boost and probibly 100 shot of NO2. Think that will do it?
Ryan
Altiman94
Car: 1989 Nissan 240SX
n2o you mean?
FrEaK
Car: Boosted D21 Pickup
The problem isn't so much making more power, it all depends on really making sure that power gets to the ground and is used to it's full potential.
For example, you want wide sticky rubber for good launchs, (with flex walls if your going all out)
Proper gearing so that your topping out 5th gear at the end of the run
Reduced weight be easier launches and better power to weight, without having to add more power and again, worry about putting it to the ground
Less rotational mass and unsprung weight...
I'm not a drag racer, but those components are just as important if not more so then just more power...
Oh i almost forgot, good reaction times, good shifts, a good driver...
-FreaK
goofynick6
Car: 1995 S14.5 RB20DET
You could do it with 600hp and weight reduction; good driver obviously.
Nick
rcodea
that reminds me, what do you recomend for the diff? i hear the skyline one is bolt up and works well. what do you think about running N2O with boost on the RB25?
Ryan
FrEaK
Get a kaaz, lifetime warenty
cyris3d
550 could get ya into the 10s, and some big tire
cyris3d
NightXCZ77 wrote:700hp to break 10's though....that's what the title of this thread is....atleast I would guess around 700 to hit a 9.
huh?
goofynick6
I think he means break into the 10's, not out of them.
Nick
TommyTheCat
Night's saying that 550-600 is good to get into 10s, but 700 is enough to break the 10sec (like in the title) and into a 9sec .25.
edit: oops, yeah. So the question is, what did he mean? Break into or out of 10s?
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
rcodea wrote:in your honest opinion, how much would it take to get S14 with RB25DET into the 10s?
HE WANTS TO KNOW WHAT IT WILL TAKE HIM TO GET INTO THE TENS.
I THINK WITH ALITTLE WEIGHT REDUCTION, STIFFER SUSPENSION (W/ LITTLE TO NO SQUAT OR DIVE), TRUE CLUTCH OR HELICAL LSD, MORE REAR GRIP, AND ABOUT 450-500WHP AND A GOOD REACTION/60 FOOT AND YOU WILL BE IN THE TENS...... SHOOT FOR A 2800LB VEHICAL WEIGHT WITH YOU AND YOUR "RACING" GAS LEVEL IN IT.
rcodea
yes i mean to get into 10a, but if its only going to take another 100 hp to break it, why the hell not.
Ryan
PROJECTRB240SX
IF YOUR GOING TO A LEGAL TRACK YOU NEED TO DO ALOT OF SAFETY WORK FOR ANYTHING 10.99 AND BELOW.
spec-u-later
Car: Yaris...FML
PROJECTRB240SX wrote:IF YOUR GOING TO A LEGAL TRACK YOU NEED TO DO ALOT OF SAFETY WORK FOR ANYTHING 10.99 AND BELOW.
Unless youplan on doing it on your fist run.:D
BoostFab
Car: S13cp, S13fb, S14z
if i remember correctly, a roll cage and helmet are what required at that speed.
Quote »600 on boost[/quote] with that amount of power, a good set of tires and suspession you can hit mid 10's easy.
93RPS13
Car: Cars, Girls, Cars, Food
FrEaK wrote:Get a kaaz, lifetime warenty
really so if i break one and theyll cover it?? sorry for hijackin
FrEaK
Yep...
Take a gander at their site...
FrEaK
Yep...
