vliou »
https://forums.nicoclub.com/vliou-u56665.html
Tue Apr 17, 2007 9:22 am
Flush your fluid once every 2 years! Pls pls pls don't be one of those ppl who ONLY do oil changes...
There are several things to do! Here's my list: I always keep it updated =)
QX4 Service
---------Remind Service Dept Every Time:-------NITROGEN TIRES -->Do not adjust (every time)DO NOT LET NISSAN ROTATE TIRES (Every time)MOBIL 1 SYNTHETIC 5W30 OIL
----------Time Dependent--------------------
Oil Change = December 15, 2007Brake Fluid Flush - December 15, 2007 (every 2 yrs)Inspect Steering gear (box) & linkage, (steering damper 4X4) axle & suspension parts = December 15, 2007 (every 1 yr)Inspect Drive shaft boots & propeller shaft (4X4 ) = December 15, 2007 (every 1 yr)Inspect Steering linkage ball joints and front suspension = December 15, 2007 (every 1 yr)Inspect Exhaust System = = December 15, 2007 (every 1 yr)
LSD Gear Oil (Rear Diff) -->April 15, 2008 (every 1 yr)S1 Package (Inspect Brakes) = April 15, 2008 (every 1 yr)PowerTrain Flush : April 15, 2008 (every 2 yrs) (Does this include LSD? If not, remind them!)PowerSteering Fluid = April 15 2008 (every 2 yrs)Replace front wheel bearing grease and free-spinning hub grease = April 15, 2008 (every 2 yr) (S7 package)
Coolant Flush = April 15, 2009 (every 2 yrs) Cabin Air Filter = April 15, 2009 (every 2 yr)
Air Condition Service - Feb 27, 2010 (every 4 yrs)
----------Mileage Dependent------------Lube prop shaft 78000km (every 12000km)Tire rebalance 81000km (every 10,000km)Sparkplug. 96,000 km (every 96,000km)
Fuel Filter Replace - at 96,000km (every 50,000km)Engine Air filter at 118,000 km (every 48000km)Replace Drive Belts 120,000km (every 60,000km)Timing Chain - Don't replace
