Scandinavian Flick »
https://forums.nicoclub.com/scandinavian-flick-u100311.html
Mon Aug 04, 2008 5:24 am
the a/c must come with some crap brakes,
as for wether they are going to put on new pads.. only if you pay for em, they will tell you its a wear item and that it is not covered,
my advice, take the caliper off and use some sandpaper to sand on the brake pads this should remove any hardened spots on the pads therefore removing the squeak,
unless you ride your brakes like there is no tomorrow, then your pads could be worn down to the wear indicator, meaning they need replaced, but i seriously doubt that
