NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Fri Mar 18, 2005 4:05 am
that brake light on the dash comes on for 2 reasons. either your ebrake is up or your fluid in your brake master cyl resivior is low. probably the latter. if the fluid is low look at your brakes and make sure your pads are not getting thin, may be time for a brake job. If all you brake pads are over 2 mm to sensors, look to see if you have any brake fluid leaks anywhere. The master cyl capacity is designed in such a way that when your brakes are getting close to being warn out the fluid level drops to the point it turns the light on. This is from normal fluid transfer to the calipers as they travel out in their bores. Then once you have a brake job done ,when the calipers are compressed back into the bores to allow room for the new pads the fluid tranfers back to the master cyl filling it back up.
my guess is the light tends to come on when going into a long turn or when accelerating from a stop. The sloshing of the fluid allows the light to come on.
