J-Owner wrote:If you use the lower octane gas the engine will ping and then you will have to have the throttle body cleaned ( I think that is the thing or heads or something) Honestly I fogot what it was called it has been about four years.
Anyway, I put low octane in my J30 for a while and had to pay to have the pinging resolved.
While it might be a lease, until that lease expires YOU are responsible for the maintenance, so unless you want expensive bills later, use what is recommended, Premium only.
Pinking AKA Engine knock can occur with lower octane fuels, but OEMs generally design their motors to run safely on regular unleaded gas. It may affect performance and gas mileage, but it should run safely on it if everything else is working correctly.
Having to clean the throttle body? Doubt it. In fact, unless you were using a low octane furl for a long duration, no immediate harm would be done. At worst, low octane fuels would end up with more carbon deposits as the detergents are fewer, but pinging would not cause this. Carbon deposits can actually contribute to detonation but are not a result of it. The big concern with pinging is actually damaging the internals of your motor, ie rods, pistons, cylinder walls, valves, heads).
